Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
HDD Replacement on PS3. Can cant one 40 gb go into another?
I have 2 ps3s in repair. After fixing one, on the second reflow, I finally backed up the data. Then I attempted to swap one hard drive into the other ps3, but could not. The message said the wrong HDD was in the ps3 and needed to be formatted. Why can I not swap 2 different HDDs? same size, both 40 gb..
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
With the PS3 you can't just go and swap out the drive. The drives are mated to the console/main board. So each console needs to format the drive to mate with it. Otherwise it is not being recognized.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
So say it doesn't work again, what if I put the mainboard and HDD with a diff fan and power supply?
tarafından
I would think for as long as you keep your board and drive mated, should not be a problem. Sure is an interesting question :-)
tarafından
Yorum Ekle
Yanıtını ekle
Aaron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 838
