Ana içeriğe geç
Sony Alpha a6400 / ILCE-6400.
How to change top flex cable or on/off block?
Sony a6400 on/off switch
Hello, my a6400 simply doesn’t turn off, even when I switch to “off“ position, the camera works just fine, the only issue is that I have to take the batery out to turn off the camera.
I suspect that the tiny lever from the flex cable os broken.
I need a step-by-step teardown of this part of the camera, ir order to replace the top flex cable or the whole block if it’s easier, below are the images of the components I need to replace;
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@arturjeronimo the only thing I can offer is the SM ILCE6400 which will show you step by step how to disassemble your camera. Now once you follow that manual, remember to help out the next person ;-)
While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
artur_jeronimo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 492
