Ana içeriğe geç
The DOSS SoundBox can be identified by its model number: DOSS SoundBox on the base between the feet of the speaker. Its a fourth generation bluetooth wireless audio player that was released in 2016.
Can I replace battery with Higher mAh capacity?
Both batteries are 18650. Using same BMS. But one has higher mAh rating. Is it possible to replace current one with higher mAh ?
My worry is how speaker tracks battery capacity and charges battery. Say original battery capacity is 2200 mAh, is replaced with 3500 mAh with same BMS and everything. Will it charge battery to full capacity of 3500 mAh? or charge level will be limited to 2200 mAh.
Also, would using higher C rated battery damage speaker or components ?
Thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
A higher capacity cell will not damage the equipment. It does not force current through the equipment. How it charges depends on the battery management IC or algorithm in the device. Charge termination is usually detected by taper current — the cell accepts less current as it reaches full charge. There can be backstops such as maximum charge time which could, but probably wouldn’t, limit the maximum charge state. A separate question is the effect of taper current (a percentage of capacity) with a larger capacity cell, which will have a larger taper current. This means the charge will be little more aggressive, since it will still wait for the lower current. It also depends on how much the design pushes the envelope. It has been common for manufacturers to charge the cells as much as possible in order to claim a higher capacity (especially in laptops). It’s not good for cell longevity, though. This consideration should limit the capacity you choose.
Brendan Harkreader (DOSS SoundBox Battery Replacement) recommends the same capacity (a nice conservative choice), in a protected cell, which is also a very good idea, since we don’t know the actual safety design.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Anand kumar, yes, you can for as long as it physically fits. Your BMS should allow you to use it as well. You may get a bit longer playtime from your audio player but remember that it will also take a bit longer to charge it up again.
Puan 2
Yorum Ekle
Yanıtını ekle
Anand kumar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 126
Her zaman: 12,253
