Ana içeriğe geç
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
Phone will no longer wireless charge.
Hello, I just want to make sure I can actually fix this issue. Long story short I dropped some tools on the back of my S10+ which cracked the back glass and caused it to no longer wireless charge. I’m assuming that if I replace the back that it will fix this issue but if that is not correct, is there any way to fix this?
Update (02/14/2022)
I know that I need to replace the charging coil but I was wondering if that is included in the back replacement or not.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@nickbee95 Wireless Charging Coil Is Not included With Back Glass Replacements As it Is Glued to Midframe Not Glass
More Over if the Coil Is Damaged Then Wire Charging Will also stop ,so if you can still charge phone via cable then problem is not from coil,
Maybe With PCB Or Charger Itself
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
@MANPREET SINGH Virk Hmm well thank you for the help. I just tried using my wireless charger with a different power strip and it seems to be working so I will leave it at that. Thanks again for the helpful info!
tarafından
Yorum Ekle
I have s10+. I have updated it on android 12 then the screen starts flickering with a yello green tint on it. So i myself decided to teardown the back cover. I found that the issue is the wireless charging coil. When i disconnect it to the motherboard my screen back to normal there were no screen flickiring anymore but my problem is my phone wont charge if the wireless charging pad is not connected. So anyone how will i troubleshoot this problem. Any answer on how to charge my s10 plus even without the charging coil. Pls help me!!!
Puan 0
Yorum Ekle
Yanıtını ekle
Nicholas Bell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 831
