Blu-Ray drive disc opening dust brushes
I need to replace the dust brushes around the opening where the game disc is inserted but can’t find the part or any info on replacing this. Is this possible to replace or do I need to buy a whole new drive just to replace the dust brushes covering the slot?
Bu iyi bir soru mu?
Puan
0
Is that part attached to the top cover of the drive with the magnet etc.? If so then you can just replace the top cover of the drive.
Jay C. Landgraf tarafından
Appears to have been most likely press fit into the console chassis opening slot. Not sure if a press fit or attached to the drive itself as it was sucked up by the vacuum (oops, too much power) that’s how I ended up needing a replacement. Vacuum mangled original.
Brett Taylor tarafından
