Ana içeriğe geç
PlayStation 3 Slim, orijinal model numarası CECH-2000 olan PS3 video oyun konsolunun ikinci sürümüdür. Sony Computer Entertainment tarafından üretilmiştir ve orijinal (Fat) Playstation 3'ün birçok sorununu gidermiştir. Ürün 1 Eylül 2009 tarihinde piyasaya sürülmüştür.
CECH-2101B only reads dual-layer Blu-Rays when held vertically?
Basically the problem is this: I can load most PS3 games into my CECH-2101B PS3 and they start up just fine. However BD movies and PS3 games that are dual-layer (aside from GTA5 for some reason) do not unless I physically lift the console and hold it vertically (with the disc drive pointing upwards).
Is this a laser issue and can I fix it by swapping the laser?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It just needed a new laser. Done and done.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
This is very similar to the problem that a lot of PS2s (Primarily Slims) had where they would only read certain discs unless the console was in a certain position. The fix for those was a new laser, so based on the symptoms you have provided, we can safely assume it’s the laser. One thing I would check though is to make sure it actually spins properly if it does, then I would try the laser. If it doesn’t, then there’s a problem with the drive and it would probably have to be replaced. Here is a guide on how to remove the drive from the console to replace the laser or the drive itself: PlayStation 3 Slim Blu-ray Disc Drive Replacement
Puan 2
1 Yorum:
It definitely spins correctly because I can feel it while I'm holding it up (I can even feel it reengaging after it gives up the first time). Plus, as I mentioned I can read single-layer Blu-Rays (meaning the BD laser itself is alive) and CDs/DVDs.
tarafından
Yorum Ekle
Yanıtını ekle
SolidSonicTH sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 606
