Ana içeriğe geç
The BlackBerry 8830 is a smartphone that instead operates on CDMA2000/EV-DO networks and includes GPS.
2 Soru Tümünü görüntüle
My blackberry 8830 blank out the screen
i have this blackberry 8830, it was working fine, but suddently the screen turn completely white, I turn it off and on back and didn't restore the screen. Now a have a BB that have a white screen that i can not anything.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
most bb I've had with a white screen need a new LCD
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Not sure if you already tried to remove the battery to reset the BB. You also want to try to reload the OS by using your Blackberry Desktop software. now what I read earlier, while researching another question, was that there is the possibility of a shortening out of some pins. Check on here even so it is for a Curve, it still applies to your phone as well. Hope this helps and gets you started.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi, how are you? You must replace your LCD screen, before buying a new piece, look the backside on the broken LCD, there's a serial a number like: 007/111, 001/111. That's your LCD number, you must buy a new one that have that serial number. If you look around the site you'll find some guides that explain how you can replace the screen. I hope this helps you! Sorry about my English. Good luck.
Puan 1
Yorum Ekle
Agree with gonzalobonini, you'd better pay attention to the LCD serial numerber
Puan 1
Yorum Ekle
Dismantling screen
Dismantling screen
Dismantling screen
Dismantling screen
Puan 0
Yorum Ekle
Yanıtını ekle
Ricardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 1,437
