Seagate backup plus desktop drive 4tb turns on and off.
STDT4000100 Seagate backup plus desktop drive 4tb turns on and off while connected to my computer.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Probably a power supply issue. Just make sure the (12V 1.5A look on the label on yours) polarity is correct. You will usually see a little diagram with three cirlces. The first will have either a + or a - symbol with a line to the edge. The third will be like the first but with the other symbol and a line going to the black dot in the centre. If it is not the power adapter then the drive enclosure may be the problem.
Bu yanıt yardımcı oldu mu?
It was the USB power-saving feature.
There you go Ben, a simple solution. Good one!
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 379
