Ana içeriğe geç
Hybrid laptop/tablet manufactured by Microsoft. Released November 2017.
Are base battaries compatible between 1835 and 1832?
I own a SB2 13.5 model 1832 and the base battery doesn’t hold any charge. it won’t turn on without a charger.
The only replacement base battery I can find is for the 1835 model. would it work with the 1832 model?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Did you replace the battery with the 1835? and did it work?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can check it by reading information about the wattage on the batteries. Compare the power between both the batteries. If there is the same watt and volt, then you can use it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
mohammud Ali sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 655
