Ana içeriğe geç
Casio fx-9750GII, Casio tarafından satılan bir grafik hesap makinesidir. Hesap makinesinin ön yüzünün sağ üst köşesindeki "fx-9750GII" başlığından tanımlanabilir.
Why are my function keys not working properly?
My function keys are not working properly.
In Run-Math program, if I press F1, nothing happens. If I press F2, it opens a list of options in the botton (LIST, MAT, CPLX, CALC, STAT). If I press F3 it opens another list of options (V-WIN, FACT, STAT, GRPH, DYNA). If I press F4, it acts as going into the previous screen (For example, If I am in Run-math and I was in the menu before, it goes to the menu and if I press it again it goes back to the Run-math). F5 acts as the Left arrow key in text editors. F6 acts as moving back a line (selecting the previous line).
Every other button work as intended.
I tried to reset the system through the menu, but since the function keys aren’t working properly, I can’t select the reset option. I’ve also tried the small button on the back of the calculator, but it doesn’t do much.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hello Ricardo, did you maybe had a spill onto the keyboard?, also if the unit is old, ( i don’t know how old) some buttons might stop working , like buttons of tv remotes, it might be worth it to open the whole thing to have a look if its dirty or worn out . if its worn out, there is a conductive glue available from specialised electronic shops, just cover the tip of the missing carbon rubber with a very thin layer of the conductive glue , wait for it to dry, reassemble. also while you have it open, maybe then you can check if bridging corresponding pad of the reset option would do anything. good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Try to redownload the program. I had the same issues and it helped me. It gave me a lot of problems because I used it for education. Fortunately, this site https://plainmath.net/textbooks/ saves me from failing lessons. But maybe someone has other more smart suggestions?
Puan 0
Yorum Ekle
Yanıtını ekle
Ricardo OKay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 1,509
