Ana içeriğe geç
Sony GTK-XB5, 2016 yılında piyasaya sürülen, Bluetooth özellikli yüksek güçlü bir ev ses sistemidir. Bu ses sistemi siyah, kırmızı ve mavi renk seçenekleriyle mevcuttur.
How to fix my power jack
Resim
Resim
Resim
Resim
I have tried to solder it back together but I am not sure if I have done it right can solder arc between it self as there is a small gap in the solder I did manage to turn it back on for a few seconds then it died then when I tried again there was a spark from the power jack
Bu iyi bir soru mu?
Puan 1
3 Yorum
@andrewlang00 post some pictures of the jack and teh repair etc. with your question. Let's see if there was a solder bridge or similar that may have caused this. Mevcut bir soruya görsel ekleme
tarafından
@oldturkey03 added photos also I am very aware my soldering job is terrible hopefully the pictures help tho
tarafından
It was fixed to the board better when I first tested it but taking it in and out has loosened the solder
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It looks like these are "cold" solder joints, which means the connection between the pad and the pins are not good, which would explain the sparking. Try to touch your soldering iron to the pin and the pad and the same time to heat up both and then apply solder so it covers the pin and the pad for a flawless connection.
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Andrew Lang sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 354
