Ana içeriğe geç
26 Ekim 2018'de piyasaya sürüldü. A1984,A2105,A2106,A2108 Modelleri ile bilinir. GSM veya CDMA/eSIM , nano-SIM veya dual-SIM / 64, 128, veya 256 GB / Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı. ("iPhone 10 R." olarak telaffuz edilir.)
468 Soru Tümünü görüntüle
Changing the front camera, does it break face id
I am tempted to buy a phone which needs a screen replacement and from the sounds of it a new front camera because the image is blurry. the buy says that face id used to work but when the camera went blurry it stopped. Does changing the front camera brick face id?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, it does. It is a very stupid measure by Apple.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Does this apply to other devices with face id?
tarafından
@cerealsneaky yes, all of them
tarafından
Yorum Ekle
A DIY replacement will render face ID lost.
But a micro solderer will be able to repair/replace the dot projector which is usually what fails for face ID.
Puan 1
2 Yorum:
%#*@ i wish i could do that lol
tarafından
It's sooooo fiddly.
You can buy a JC programmer (also used for truetone) and buy replacement JC flex.
Data sucked from old flex, and programmed into new.
Then dot projector is removed, and then within that dot projector, a resistor is removed, along with a transistor, which 2 points are bridged together. Reassembled (precisely) and then it'll work again.
I've tried it, but still not mastered it yet, such a small component to work on!
tarafından
Yorum Ekle
Yanıtını ekle
dan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 1,027
