Ana içeriğe geç
Samsung RS25H5111 buzdolabı için onarım ve ek bilgiler; 2014 yılı yapımı, otomatik buz yapıcılı ve kompakt, dahili özelliklere sahip, dondurucusu yan tarafta bulunan bir buzdolabı. Bu sayfa, RS25H5111** modeliyle eşleşen model numaralarına yönelik bilgileri kapsar.
RS25H5111BC temperature display incorrect
Temperature is set to 0 & 37. Every day or two, both sides will get warmer than that even though the display reads 0 & 37. I am able to have it function properly by removing power, restore power then reset the unit by pressing and holding fridge and freezer buttons. Compressors and fans will kick on and unit will be at proper temperature within 1 hour. After reset, the ‘true’ temperature will be displayed on the door display. Depending on how long the unit has be at fault, the displayed temperature will show 40 & 60 which is correct and verified by a thermometer. However, after a day or so passes, the both sides will be warm again.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I came to this for looking for honest advice based on others experience. I went out on a limb and purchased Samsung DA92-00624A from Amazon for $100. That did the trick and the fridge and freezer works as expected.
Manages refrigerator functions like cooling and defrosting, essential for proper appliance operation. Görseli
Ürün
DA92-00624A - Samsung Refrigerator Main Control Board
$235.99
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Apologies, I've been away for a few months. When resetting the unit causes it to read the correct temp and to run, then yes, the controller is faulty and needs replaced. Glad you got it fixed.
tarafından
Yorum Ekle
Yanıtını ekle
Joe VanGundy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,098
