Ana içeriğe geç
Ekim 2021'de piyasaya sürülen ve Apple tasarımı M1 Pro ve M1 Max çipleriyle (SoC) donatılmış 14 inç MacBook Pro için onarım rehberleri ve söküm bilgileri. Model A2442.
My keyboard has been damaged
My macbook keyboard has been damaged somehow, how would i fix it without paying 1100 dollars apple charges for a replacement, and my mac squeeks when i open it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
What sort of damage has it suffered? Is the squeaking the only issue?
tarafından
A squeaking hinge is in need of a very little bit of oil on the clutch coils. I use WD40 slightly dampened Cotton Swab and a quick wipe of the coils solves it. It takes very little oil!
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
I’m so sorry ;-{
As your system is so new there is just no parts availability. To add to this Apple has moved to major assembly replacement for many of the pieces that make up your system.
As dumb as it is, the most abused part of a system is the keyboard and it’s not officially replaceable! It’s riveted to the uppercase unit and is a bear to replace! Here’s an older model to give you an idea how bad it is Apple Really Doesn’t Want You To Fix This - MacBook Keyboard Replacement
You’ll need to pay the piper (Apple) here as much as it hurts!
Maybe in the fall we’ll have a source of the keyboard. Even still it will be costly for an independent to replace the keyboard. An Apple authorized repair shop must follow Apples direction replacing the full uppercase.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Hi
Is the MacBook still under the 1 year warranty
If it is you may be able to have it fixed for free
Puan 1
2 Yorum:
@hellomacos - Be careful! Damage caused by the owner is not covered! You spill a drink into the keyboard as an example or your friend fires off a dart at your display cracking it! If the damage is caused by a product defect that's different!
Apple does offer an extended warranty program which covers product defects longer and most user caused damage too! AppleCare + But you need to buy it!
tarafından
Will do
I just though because they didn’t mention any physical or water damage only a squeaky hinge
tarafından
Yorum Ekle
Actually, this keyboard spare part is available online for your model
Puan 0
Yorum Ekle
Yanıtını ekle
Phil Habib sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 3,297
