Ana içeriğe geç
How to replace screen glass
How do I replace the screen on this device?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Mohammed Basith Awan use something like this video or even this one for the how to. Once you are going to replace your screen, it would be great if you create a guide so that teh next person looking for an answer, can find it on iFixit. It’s not complicated to create a guide. https://www.ifixit.com/Guide/new
Now if you are thinking about a glass only repair, that would be very complicated since glass and screen are fused. You would need some special tools to separate the display and subsequently to re-adhere etc. The cost for the tools and your chances of getting it right the first are slim and expensive. Replacing the complete display will have greater success.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Haven’t worked on this one myself, but all the Samsung devices are pretty much the same formula. Remove the back, undo all the screws, remove the plates or midframe, disconnect everything starting with the battery, remove the main board and daughter board, remove and transplant any components that aren’t present in the new screen assembly (make sure to buy a replacement part with frame or you will have a much harder time), reinstall the boards, reinstall the battery, connect everything, put plates or midframe back on and tack down with a few screws to make sure the power buttons are making a good connection, test the device, if everything is good you can reinstall the remaining screws and then re-adhere the back.
Puan 1
1 Yorum:
My A42 doesn't have a removable back.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Mohammed Basith Awan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 5,084
