Ana içeriğe geç
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
68 Soru Tümünü görüntüle
Screen washed out with bright green or other colors, often flickering
One day my G020 Pixel 3a’s screen starting coming on with a bright, solid green, brown, or tan color behind its displayed image, as if every green & red pixel were stuck partially on, making it washed out & very hard to read. Occasionally it turns a more pinkish color. The spurious background lighting is usually solid, but sometimes flickers in and out, with flashing horizontal lines (in portrait orientation). Once in a while the issue goes away on its own, and the screen is perfectly normal until it’s next turned off (manually or via timeout, even for just a second) and back on, after which the washed-out color inevitably returns.
When enabled, the dimly-lit AOD with clock & notifications is never affected, always showing a solid black background as it should. The spurious background is present from initial power-up (Google logo) onward, even after entering the bootloader, which would seem to rule out a software issue. Rebooting doesn’t help, but repeatedly turning the screen off & back on via power button sometimes eventually clears it for a while.
The spurious color’s intensity goes up & down when adjusting screen brightness, but is always present even at minimum brightness on a black screen (except for the AOD somehow not being affected).
This problem didn’t coincide with a drop or other physical shock, but I originally bought the phone from eBay, so its previous owner might have been rough with it. It was being carried in the tight side compartment of a faux-leather purpose, though, which might have imparted some bending force. Trying to bend, twist, and push on various parts of the screen and case has no obvious effect.
Is there much chance that this is merely a loose screen cable, easily fixed if I can get the phone open? Or am I looking at a replacement screen? Has anyone seen a problem like this before, on any AMOLED display?
Thanks in advance for any insights!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
My brother's phone also had this issue. He was using a Google pixel 6a, and we found out through trial and error that by grabbing the top left and bottom right corners of the phone and bending gently it would temporarily fix it. He is taking it to a repair shop today, as we couldn't figure out a permanent solution.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Sounds like a damaged display to me. Usually it’s not the connector but could be worth a shot disconnecting and reconnecting it, granted you are able to get the display up without damaging it in the process which is extremely likely.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jordan Hazen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 1,189
