Ana içeriğe geç
The sixth generation of the Subaru Legacy made its debut at the 2014 Chicago Auto Show, and went into production for the 2015 model year.
2 Soru Tümünü görüntüle
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
Bu iyi bir soru mu?
Puan 0
1 Yorum
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
EDWIN CHAN MENCIAS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 257
