How can I fix my touch-bar? What is the part that I need?
So I somehow must of accidentally killed this chip damaged it enough to break it from the board, Can somebody tell me what it is and what part do I need to replace it? Can it be fixed with some wire and solder or do I need a new chip for it?
Its the left most chip that has come off
Bu iyi bir soru mu?
Your images is showing a section of the main logic board near the Toucvhbar connector. So the question is did you have a liquid spill or drop something (screw) onto the logic board when it was open?
This looks like a short as the resistor appears burnt. While replacing it will take some skills it may not be the root issue.
Dan tarafından
@danj That is correct about the logic board near the touch bar connector. I also thought the same thing about the resistor. No screws or liquid touched the board at the time though. The resistor did fall off actually as that is a bit of an older photo and after testing with a multimeter it came back to show me that all of the other resistors are working fine which explains why the touch bar displays correctly and just wont respond to touch.
Could this just be replaced by connecting the two pads without the resistor or should i actually go through the effort for the resistor?
jack tarafından
