Ana içeriğe geç
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
150 Soru Tümünü görüntüle
Wifi antenna problem or motherboard?
Hello people, today I bought a completely damage iphone 11 pro and I try to repair it, i put the new screen and the phone doesn't find any wifi, i am.trying to active it but is just saying connect with Mac or windows, so i found this problem on wifi antenna can this be the issue? Or is motherboard problem?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the Wi-Fi is greyed out it will be a board problem. If Wi-Fi is enabled and cannot find networks it could be an antenna issue.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Thanks for getting straight to the point Chris this can happen if you hit the device with enough force on a surface. The former is what occurred to my sis' ipad mini as it was smashed against a hard surface which broke that board.
tarafından
thats what happend to me now. It got smashed on the floor and suddenly it restarts itself. the wifi, cellular data, and bluetooth are all greyed out
tarafından
Yorum Ekle
Hey Stelios,
Unfortunately something has cracked inside which means that the board won't find wifi. This is likely due to a massive bend. I know someone who did this with an ipad mini 4 and had an identical problem. There is no way to fix this so sorry but this one looks to be not fixable.
Puan 1
7 Yorum:
Thanks for the answer , yes but the motherboard looks perfect and not bended at all, I can provide pictures tomorrow
tarafından
Hey Stelios thanks for the quick reply,
Just banging the device can have this happen. My sis was using the ipad mini when she raged and hit it against her knee then it was broken. We spent countless hours hoping it was software but it was indeed a hardware problem. However, my mini 4 has a bend and hasn't broken (yet). So it's something that really you need to hope the previous owner didn't hit it somewhere.
Can you by any chance provide me some photos/screenshots of what comes up in settings and control centre under wifi and other tabs that are related eg mobile data and bluetooth.
tarafından
Thanks for the answer , I will replace the antenna and we will see , but I am 80% is board issue cause the phone was smashed hard , I cant provide pictures about setting cause I can't activate it, I put the Sim the iTunes finds the phone, but nothing about new start so I can activate it via itunes
tarafından
@ibitaz There is a program called 3uTools it gives a lot more info than iTunes.
tarafından
@ibitaz to clarify is the wifi toggle greyed out?. If = yes then board is toast, if not then it could be antenna related
tarafından
2 tane daha yorum göster
Yorum Ekle
So yea guys is the motherboard the antenna didnt fix anything , thank you all for the answers to bad I don't know soldering yet :)
Puan 0
Yorum Ekle
Yanıtını ekle
Stelios K. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 50
Her zaman: 1,573
