Ana içeriğe geç
Anakartlar ve CPU'lar için onarım kılavuzları ve destek.
Soru Kapandı
Single out the hardware error
Has anyone information for determining which component is giving trouble?
Situation: PC shuts down and does not power up anymore. Power LED alluminated but all that is active is the fan. How can I confirm that the power button is giving trouble?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Depending on your specific hardware. I would start off with a multimeter and see what the power supplies does. I have had PC's that did this with bad CPU's , CMOS that needed to be cleared as well as as bad Caps and numerous other errors.
tarafından
Which pc? Model no. ?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If your computer is running slower than usual, randomly freezes or restarts, or refuses to boot, see the Motherboard Has a Faulty Capacitor problem page for capacitor troubleshooting help.
Here is a link to a troubleshooting process to help determine your problem. If that doesn't clear your problem please google "PC shuts down and does not power up" for further links that may be a help to you.
http://pcsupport.about.com/od/findbysymp...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I have replaced capacitors on several boards to bring them back to life. If any of the capacitors on the board are puffed up on top or are leaking; then that's the problem.
Just read the side of the capacitor to get the type and ohms. I get mine from mcm electronics. They carry a wide selection and good prices.
You un-solder the old one. Note the orientation before removing, that determines the +\- side. Solder in the new one.
That should do it. Most times there was more than one that popped. Check the board carefully. Good luck.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 2,426
