Why does the Aria eat batteries? (fixed)
As they get older, a FItbit Aria scale can drain four AA batteries in a week. Batteries should last months. This is apparently a common problem, possibly due to strain gauge sensors becoming flaky over time. Has anyone found a fix?
Bu iyi bir soru mu?
3 Yorum
I have the same problem to I am guessing because the contacts are touching and draining power.
Drew tarafından
I don't think mine is a contacts problem. If I place the scale in my peripheral vision, the display seems to turn on spontaneously, and then times out and sleeps. It does this dozens of times per hour, which would be the reason for eating batteries. I found several mentions of flaky pressure sensors in the feet, triggering the display. If I could find a source for the sensors, I could replace them to see if it fixes the problem.
Leonard Cho tarafından
Clean the scale of dirt buildup. Is your home very humid, possibly triggering the scale turning on? Tried customer support?
F Dryer tarafından
