Replace LG V60 swollen battery
Is it possible that I can replace the battery myself in an LG V60 ThinQ 5G?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
RAYMOND A BYRNES JR yes you can. Just follow something like this video A bit of patience and the right tools will make all the difference.
Bu yanıt yardımcı oldu mu?
this video is way to involved to just replace a battery
@rayharmacinski You may be right on this one. I'm not sure I see why the motherboard and charging board needed to be removed on this video. I found a similar guide for the V40 ThinQ that just shows the antenna plate coming off then the battery being removed. You'll have to use your best judgement as to whether this same technique will work the same for your V60 though.
https://www.nadiemellamagallina.com/en/m...
If you do end up figuring it out, you can always help others who come along with the same problem by creating your own guide to this repair.
@rayharmacinski you are absolutely right. That video is for a complete teardown. You only go as far as you need to, in order to remove the battery.
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 116
Her zaman: 4,168
1 Yorum
Chargeng problem
Ahsan Khan tarafından
