Ana içeriğe geç
Airport not being detected
I've tried multiple working airport extreme cards. None are detected. Ran hardware tests card is never detected. Verified that all cables are fine and connected. This is one of the boards that has the ram slot issue. Currently running 10.5.8. It's not detected in 10.4 either.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like a logic board problem. Can you find one of the USB wifi units to try? If that corrects the problem you can swap out the card cage which may correct your problem. Ralph
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
I tried a PCMCIA card, but not a usb. I'll pick up one and try that. I also posted a question about screen flickering, but I believe both of these were in the hope it was not a logic board issue.
tarafından
If you tried a PCMCIA card and you have the flickering problem I would suspect a logic board problem. Ralph
tarafından
I was hoping that wasn't it. But Logic Board replacement will be my next step. Thanks Ralph.
tarafından
Yorum Ekle
Yanıtını ekle
stacywebb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 7
Her zaman: 2,012
