How do I repair the window in the front driver door
How do I repair window in front driver side?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may use WD-40 lube spray. I had to pull my window up and down as much as possible! Then I attached the straw that comes with the WD-40.
Then I sprayed the tracks and other moving parts heaver than usual. Meanwhile I kept moving it up and down until it was free.
Later it successfully began to inch it up. Then I pulled it up and down until it was as new!
It is good to apply WD-40 often as a preventative!
Best wishes!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 28
Hi,
What year is the vehicle?
jayeff tarafından
Also, what kind of repair are you asking about? Please be specific
brandon k tarafından
