Ana içeriğe geç
3 MB paylaşımlı L3 önbelleğe sahip 2.6 GHz çift çekirdekli Intel Core i5 işlemci (3.2 GHz'e kadar Turbo Boost). 13 Şubat 2013'te piyasaya sürülmüştür.
wifi and bluetooth not working
my wifi and bluetooth don't work after replace the battery
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would reseat the I/O data cable which connects the I/O board (with the Airport board) to your main logic board often I find the cable connection is the issue, you may need to replace the cable MacBook Pro 13" Retina Ekran 2013 Başı I/O Kartı Veri Kablosu Değişimi if the Airport board is properly seated and the antenna cables are in good shape.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
First thing I would check is to make sure that the antennas are plugged in properly. The order of the antenna cables is kind of weird (to me anyways). Step 10 of this guide tells you which one goes where.
MacBook Pro 13" Retina Ekran 2013 Başı AirPort Kartı Değişimi
I would also make sure the cables between the I/O board and the logic board are seated properly, since that's what carries the signals for bluetooth and wifi over.
Puan 2
Yorum Ekle
Yanıtını ekle
MAXIMO MEYRELES sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 643
