Ana içeriğe geç
Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
Does replacing the Proximity Sensor flex cable disable face id?
As most of us know, any Apple device with Face I.D. functionality has that functionality linked to the front camera assembly and the proximity sensor flex cable. In past generations, damaging the proximity sensor flex was relatively easy to do on accident, and rendered Face I.D. disabled unless you employ micro-soldering to transfer the flood illuminator to a new flex cable.
I have been searching for an answer about this on the iPhone 13 series. When these phones were first released, screen replacement would disable Face I.D. unless an IC chip on the back of the display assembly was transferred. This has since been changed, but I do not know about the proximity sensor flex. No tutorials or guides that I have found have mentioned anything about transferring the proximity sensor flex cable, so that leads me to believe that it's not necessary anymore as long as you have another one.
So my question is this: Does the proximity sensor flex cable need to be transferred to retain Face I.D. functionality as it has in past generations, or is it no longer linked in the same way that it used to be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This shouldn´t affect the face id function, after apple made the proximity sensor a totally seperate part so it should work!
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I work at a repair shop and can confirm that replacing the proximity flex sensor on iPhone 13 series does not disable Face ID functionality. I assume its the same for 14's as well but haven't been able to confirm that yet.
Puan 2
2 Yorum:
What about on iPhone X?
tarafından
@sundaymarv71988 I know this is a very late response, but on the iPhone X the proximity sensor is on the earpiece speaker assembly that also includes the flood illuminator, which is paired to the phone. So while technically the proximity sensor is a separate component from the flood illuminator, in practice they can't really be separated as they're part of the same flex cable.
tarafından
Yorum Ekle
Face ID is a part of the True Depth sensor for which Apple has made separate flex cable for on the iPhone 13 and other models, including some previous generations, meaning the replacement of the proximity sensor does not affect Face ID. Any case of misuse may.
Puan 1
Yorum Ekle
note : by replacing proximity flex , light sensor stop working , seems to be pairing with iphone 13
Puan 1
1 Yorum:
If the LCD is changed the true tone and the auto brightness stop working . If its a copy screen or original used screen . Front flex cable being the original or a replacement makes no difference to face id operation. (13 onwards )
tarafından
Yorum Ekle
Hello,
I just changed the Proximity Sensor flex cable on my IPhone 13 Pro Max and I can confirm you that FaceID still works. I just had to configure it again.
Puan 0
Yorum Ekle
Yanıtını ekle
Garrett Chism sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 44
Son 30 gün: 309
Her zaman: 6,867
