Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
Only top speaker works
Hello, I have got an iPhone 8 that has a loudspeaker (at the bottom) that doesn't produce any sound. Only the top speaker makes sound. I replaced the loudspeaker with another loudspeaker bought online; this didn't fix the issue. I already restored the iPhone, factory reset, etc. I have attempted to change the left/right channel audio balance via Accessibility settings, I have tried basically every software solution out there. Despite this, the bottom speaker doesn't work. Any help would be greatly appreciated.
Bu iyi bir soru mu?
Puan 1
6 Yorum
So you have physically opened the phone up, and replaced the speakers with a different set of speakers?
tarafından
@jmehnert
Yes I opened the phone up and I have only replaced the bottom speaker. This is the place I bought it from.
https://repairoutlet.co.uk/products/appl...
This is the correct part right?
tarafından
Do you have the repair guide that you used?
tarafından
@jmehnert I used a youtube video, I can't remember which one. Why is this relevant?
tarafından
@mintaka It helps me to understand the process that you took for the replacement for this part, and it helps me to backtrack any steps that may have been missed. Do you think you can find it in your viewing history?
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is not the speaker you need to replace. You will need to replace the charge port assembly as it has the audio lines that go to the speaker. This is the first part to replace when the bottom speaker is not working.
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
Thank you, so should I purchase this part?
Then, replace that flex cable?
tarafından
@mintaka Yes. That is the correct part.
tarafından
@imicrosoldering cool, should I accept this answer here and then test it when the new part is replaced, once tested then decline if it didn't work? Also, how did you know what to do with this speaker problem? I scoured the internet looking for any website I could find that fixes this exact problem, and all I could find was "restore the iPhone", "take it to a genius bar", etc. Is there like a pdf or something that outlines ways to fix any part of an iPhone?
tarafından
@mintaka You can accept the answer when the audio is working. I have been working on iPhones for over 5 years and since you have ruled out software and speaker it is the only part left. I have never encounter a faulty speaker on the iPhone 8 it always ends up being the charge port assembly.
tarafından
The new charging flex works! Thanks for the idea. No more broken speaker :)
tarafından
Yorum Ekle
Did you replace charging flex and try
Puan 1
1 Yorum:
Yes. This worked, thank you for suggesting this.
tarafından
Yorum Ekle
Yanıtını ekle
Mindaugas Brazlauskas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 90
Her zaman: 6,700
