Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
375 Soru Tümünü görüntüle
XS Max - back glass BROKE. What should I do?
I have the option to get a $30 back glass replacement, or a $100 back housing replacement. Since this is a rather old phone, I want to spend a minimal amount. Will glass replacement be okay?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
back glass replacement is fine depending on who is doing it and what method they use to remove the old glass
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The rear housing is what virtually every other part in the phone is mounted on, so replacing the rear housing isn't just any old part swap, but more like a complete disassemble and rebuild of the phone. If you can get away with just replacing the rear glass, definitely a far better option. As long as the case isn't bent or distorted, the glass can be professionally replaced to where you would never know it had been broken.
Puan 1
1 Yorum:
depends if its a pulled housing or a copy, copy back glass or glass of similar thickness. genuine housing with copy port. all leads to if its done by a good tech it should be fine
tarafından
Yorum Ekle
Yanıtını ekle
Chip Demise sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 70
