Ana içeriğe geç
Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Soru Tümünü görüntüle
2002 Harley-David Ultra Classic sputters at 1/2 tank gas.
What would cause my 2002 Harley-Davidson Ultra Classic to start sputtering and throttle body backfiring after using 1/2 of a full tank of fuel? I refuel to full and it runs fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Ruling out water contamination (water settles and heavier than gasoline), is it possible for restriction in the fuel line and/or shutoff valve (if they're still used)? Ethanol blends attract moisture and can cause premature corrosion in fuel lines and metals. Fuel may also corrode carburetor parts.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Don’t know if this is true for HD, there has to be a vent in the top of the fuel tank to let air in as the fuel level goes down. If this vent gets blocked, the area above the fuel forms a partial vacuum. This restricts the fuel supply to the engine.
Test , when you experience this problem, open and close the fuel cap and if there is a blockage, the engine will run normally.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Wasn't the case in my situation but thanks for the idea.
tarafından
Yorum Ekle
Yanıtını ekle
Buggs Clark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 20
Her zaman: 249
