Ana içeriğe geç
Screen Flickering
From what I have determined through testing, the screen will flicker (more accurately it appears like an old film). This occurs when the main processor is in use. The flicker goes away when watching a dvd. OS is 10.5.8, same issue occurs with 10.4.11 This board has the known ram slot issue. How can I fix the flickering?
Bu iyi bir soru mu?
Puan 3
2 Yorum
What is your question?
tarafından Paylaş
Edited to be a question to satisfy Nat.
tarafından Paylaş
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi! I'm wondering if this happens in all screen resolutions and color depths? You might try switching to a different resolution just to see. While unlikely the answer (due to the fact you've tried two different operating systems), I have seen machines go into odd screen resolutions when a DVD is played, or when external video is used (I assume to accommodate the limitations or specs of the external image). Also, I always do PMU and PRAM resets on malfunctioning machines, just to rule that out, because funky settings in PRAM can cause any number of problems. Hope that helps.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
tarafından Paylaş
Yorum Ekle
your anwer is,wait for it ........... there is nothing you can do about the
Apple guys diasbled the solution url for that problem because of the product line factory problem they failed to fix.and that is the reason why you no longer find them on the shelves,they were dicontinued for that same reason.Shame on you Apple
Puan 1
Yorum Ekle
Try an other Inverterboard that controls the backlighting and so the flickering. Maybe some cables are on wrong position. Check temperature of the CPU with iStat Pro widget. Is there a flickering when you connect a Display to the DVI Port?
Puan 0
2 Yorum:
Corrected spelling
tarafından Paylaş
[url=http://slot-888.co][color=#e1e1e1][size=1px]slot[/size][/color][/url]
tarafından Paylaş
Yorum Ekle
Kenapa skrin menjadi berkelip kelip
Puan 0
Yorum Ekle
Yanıtını ekle
stacywebb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 4,627
