Computer restart’s when playing games.
Is it the gpu or the psu?
Bu iyi bir soru mu?
Start with the simple easy stuff. It used to work fine now it doesn't. If your case has filters, clean them. Check that all fans are working and that they are not full of lint, dust, fur or what-have-you This includes those on you CPU and GPU in particular. Is anything blocking your airflow into or out? Have you moved it so that now there's obstruction that didn't used to exist, Wall? Carpet?(Shudder), other equipment? Install speedfan (its free) now you can see the temps, fan speeds and figure out what is overheating as well as configure your cooling or use whatever software you prefer to achieve that. Once you identify the culprit, assuming a good cleaning and good airflow didn't work it will be time to consider hardware issues beyond dead fans. Replacement of thermal paste might help if it is more than a year old... otherwise the diagnostic. Information from speedfan should make further action pretty. Clear. Speedfan https://www.almico.com/sfdownload.php good luck. Do remember to power off and unplug it while fooling about inside, for your safety and your computer's.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 898
10 Yorum
What GPU are you using and what games are you playing?
guardian10 tarafından
I use an rtx2060 like i can play league of legends no problem, but i tried hearts of iron 4 , 12 minutes , metro 2033, red dead redemption 2( which it used to run without any problems)
Rares-Adrian Vîlceanu tarafından
@Rares-Adrian Vîlceanu The GPU should be good enough for those games.
What is your system's temp, and what CPU are you using?
Jacob Mehnert tarafından
What wattage does your PSU supply? Also, what CPU are you using?
shingle tarafından
5 tane daha yorum göster
