Cant find drive, OS install questions. Im stuck.
BACK INFO.
Mac $@$* the bed one day, cant see HD in recovery mode but could see SSD
I just finished replacing the HD with a brand new 4TB, I also installed the heat sensor as per recommendation.
I boot into RECOVERY mode and all I still see is my SSD in disk utility
If I select restore from back up or install OS it doesn't show the new HD or the SSD
SO NOW WHAT?
Can I install the OS onto the SSD from a memory drive so the computer can be usable even if I cant get the HD working? ( I saw it wont let me patition the SSD, but I can erase and format it. If I do that in recovery mode wont it remove the RECOVERY mode from the SSD ?)
Do I need to do the memory drive OS install to find the Hard drive?
Do I need to remove the heat sensor all together?
Im literally back to where I started before opening up my IMAC.
Bu iyi bir soru mu?
