Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Soru Tümünü görüntüle
How to fix iPhone not connecting to wifi
I have a iPhone 6s plus that when I try to connect to wifi the button is grayed out I have reset the network setting and just all settings and I still cant get it to work I'm going to try and update it but i don't think it will work any other things i can do
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
the wifi chip needs replaced
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
ok i will try this
tarafından
@keith_themuscovyduck Remember you will have to unbind the Wi-Fi Address from the NAND if you replace it.
tarafından
Yorum Ekle
If the setting is greyed out, more than likely this is a hardware issue. You can certainly try resetting the device, but in all likelihood, it will not make a difference. Either the chip needs to be replaced, or something in the WiFi circuitry has sustained damage or has gone bad.
Puan 1
Yorum Ekle
Yanıtını ekle
keith_themuscovyduck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 59
