Ana içeriğe geç
Repair guides and support for a wide range of kitchenware.
Clean the limescale on the kettle
We have a disc electric kettle at work, we use it for more than a year, there was a scale on the disc, it became unpleasant to drink tea. Just rinse and rinse does not help, what can you clean? I would be glad to hear your suggestions!
Bu iyi bir soru mu?
Puan 1
1 Yorum
Fill pot to minimum level, add a teaspoon of cream of tartar. Stir contents or swirl the pot a couple of time to mix the powder with the water. Boil water until it shuts off. Pour out contents. Rinse pot several times.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Buy some citric acid power and put a table spoon to the kettle with water. Boil the kettle and most of the calcium should break off and dissolve. After the kettle has cooled rinse with water and wipe clean. If it has not removed all the limescale just repeat. Citric acid is food safe and natural.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Run vinegar through it (boil it) a time or three this will remove the mineral deposits repeat until you see its all good. The vinegar is acidic and especially heated eats the basic lime away.
Puan 5
6 Yorum:
Agreed. Vinegar makes an excellent calcium/lime deposit remover. OP make sure you let the vinegar sit on the scale build-up so that it has time to work!
tarafından
Brandon is right you can heat it before end of day then leave it soak overnight (off, for safety)
tarafından
You could even use some lemon juice or something as well
tarafından
Anything mildly acidic,. Yes. Coke for example LOL.
tarafından
This also works on shower heads and so on. As Brandon pionted out soaking helps so does agitation. Heat speeds up chemical reactions. A bit of scrubbing once softened helps too.
tarafından
1 tane daha yorum göster
Yorum Ekle
baking soda and boil it 2 times and then do it the 3rd time with plain hot water then tip it out and put fresh water in it and its ready to use again.do that every 3rd week
Puan 1
1 Yorum:
Baking soda is wonderful stuff for removing/controlling odors, will cut grease quite well and lots of other things but its a base, not an acid so this will work to control odors, yes.
tarafından
Yorum Ekle
Yanıtını ekle
Lia Hughes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 119
Her zaman: 1,715
