Ana içeriğe geç
iPhone 11 boot looping on DC power
Hello, I have an iPhone 11 which does not turn on. On the DC power supply, when I press the power button it does a normal boot sequence until about 120 milliamps, before going to 0. The boot sequence only lasts about 3-5 seconds. It just loops infinitely like this, and does not stop. 120 milliamps is the most it has reached and I'm not sure exactly what might be shorting. Does anyone know which chip or line this may be related to? Thank you!!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Have you ruled out parts and software?
tarafından
Yes, I have ruled out parts and software. It is certainly a motherboard issue, right when it reaches 100 milliamps it drops to 0. It doesn't hang on 100, just drops to 0 immediately.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This problem shows after dropped/water damage you don't mention. Check the capacitors near Nand or audio ic most be shorted in that case. So, you have to separate the PCB first and check might be loose contact with the CPU to PCB also cause such issues.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello, this phone was not water damaged and there is no signs of drop damage. I have separated the PCB, and did a visual inspection around the motherboard. From what I could see, nothing looked burnt or out of place. The main NAND lines also tested alright. I'm thinking there is a chip on the boot circuit which is shorting out and causing the phone to not boot, but I am not 100% sure.
tarafından
Check light-related circuits. I also saw the most problems with light-related circuits.
tarafından
Yorum Ekle
Yanıtını ekle
Colby Morris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 103
