What If the #1 led is blinking
What If the #1 led is blinking and #2 and #3 are unlit?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
LED #1 + LED #2 + LED #3 + LED #4 = Power available, system is powered on, video card found, and internal LCD found.
If fourth LED is not visible after power on:
• Verify cable connections between LCD panel and logic board
• Inspect LCD display cables for cable damage
• Verify external video functionality, and according to result check the following items:
-If external display works then verify/replace LED backlight board
-If external display works then verify/replace LCD panel
-If external display does not work verify/replace logic board
Looks like you are having issues with the power supply detecting/supporting the logic board. Verify power supply first and reseat all the cables as well as your RAM modules
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 54
1 Yorum
Randy Canning it's easier this way than all the comments:-) Let us know what model and year your iMac is?
oldturkey03 tarafından
