Ana içeriğe geç
Mart 2016'da Samsung tarafından yayımlanmıştır. Model SM-G930V.
Screen Flickering When Charging - Grounding Issue?
Hi there,
I've repaired a Samsung Galaxy S7 with a replacement screen (the old one was smashed and completely dead.) The replacement screen came with the frame and a new charging port assembly.
The phone seems to be working great after the screen replacement. However, when charging the phone, the screen slightly flickers. This only occurs when the phone is being held by the metal sides - if it's in a case (e.g. the metal sides are not being directly touched), there is no issue.
This sounds like a grounding issue to me. The charging port assembly cannot be easily removed by the looks of it, as it seems to be attached under the screen. I've also tried another cable and charger, which presents the same issue.
Is there any other likely cause of this grounding issue? If anyone could provide any pointers I would be very grateful.
Thanks for your help!
Ben :)
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This happened to a friend of mine and found that the digitizer display was slowly going bad (dying),
It was still under warranty he got it replaced and had not had any issues thus far.
Good Luck! :-))
~Ibuprophen
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi,
Thanks very much for the help! I'll see if I can get a replacement display assembly.
All the best,
Ben
tarafından
Yorum Ekle
Yanıtını ekle
Ben Garrod sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 3,034
