Ana içeriğe geç
Valve tarafından 25 Şubat 2022'de piyasaya sürülen, LCD ekranlı, el tipi oyun konsolu Steam Deck için onarım, söküm ve sorun giderme bilgileri. 1010 model numarasıyla tanımlanır.
Broken jack connector after falling
hello, I am looking for the reference of the jack connector to replace it, can you help me?
FYI all pin of the connector broke after a 20cm fall with the jack plugged in
Bu iyi bir soru mu?
Puan 0
1 Yorum
I found the reference for the jack connector only if this can help someone else :
brand : WNRE
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi there,
as you might have noticed we just made a bunch of Steam Deck parts available in our stores.
We definitely have a guide for this problem (but not that specific spare part, yet). So make sure to check back for more parts that might join the current selection (though I can’t promise anything since I don’t know). Hopefully, you can manage until this part is available.
Meanwhile:
As I understand it the actual headphone port on that audio board is broken, which means you might try and fix it by soldering as long as the solder joints on the board weren’t damaged.
If it’s "just" the headphone jack itself (TRRS plug from your headphone) that got stuck in the port you might be able to get it out using this nifty tool.
Cheers and game on
GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacks Görseli
Ürün
GripStick Headphone Plug Extraction Tool
$24.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,111
