Will charge 3 connect to Extreme
Will a JBL Extreme 2 or 3 blue tooth to my Charge 3 ? Is Extreme Connect or Connect +, I believe Charge 3 uses connect?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
As your Fitbit watch has bluetooth capabilities, this should not be an issue. If you follow these steps you should be able to pair the two:
Note Should this not work please power off both devices, and start the procedure again. I hope this helps and if not please return and we will assist further to get you all set!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 172
