Ana içeriğe geç
No spark even after replacing coilpack and crank sensor
I have a fiat palio 1.6 16v, car was driving fine, just stalled on pull away and struggled to go up a ramp, i removed the throttle body to clean it with wd40 and the intake sensor. Put it back and then car did not want to start, checked for spark and there was none, i got a crank sensor from my friend who broke up a fiat palio and when i fitted it, the car started up and revved it up about 4 times. I then let it cool down and tried to start it again but again there was no spark, i went to purchase another one and still no spark, i then replaced the coilpack and yet no spark. There is power on the wires that plugs into the coilpack and crank sensor, i need help urgently. Does the 1.6 palio have a cam sensor and where is it located and can that also cause no spark.
Update (05/29/2022)
Its a 2002 as per the papers, i replaced the crank sensor and coilpack but yet no spark
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
@ayyoob what year is your Fiat?
tarafından
Did you check for blown fuses?
tarafından
There is nothing, i am going to take the ecu to an auto electrician to check whether the ecu is maybe faulty, but furthermore this car has me puzzled. This my first time having such a headache with car
tarafından
I have the same problem, but havent replaced any parts yet.
hope to benifit from your investigztion and save some frustrations and time here, what was the final fix for your problem?
Thanks
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ayyoob yes it does have a camshaft position sensor. See the attached diagram
. I would try to have the OBD scanned and see if it throws any kind of code.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
So can the camshaft sensor also cause no spark and where is it located, its it on top of the motor or the front of the motor as in the diagram.
tarafından
@ayyoob yes it can and should be located as shown on the image. I don't have a service manual for the 1.67 only for the 1.3 and that is different. WE need to keep our eyes open for more literature on this:-)
tarafından
I youtubed it now, the one cam pully must be remove, as the camshaft sensor sits behind it, i just hope that is the issue, as the car was driving well, it only stalled on pull away when car was warm and could not go up a ramp other than that car was fine, then just all of a sudden it never wanted to start and never had spark
tarafından
@ayyoob I hope so to for your sake. I hate it when stuff like that happens out of the blue. PITA to fix and diagnose.
tarafından
Yorum Ekle
Yanıtını ekle
Ayyoob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 2,711
