Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
NTC error after FaceID Repair
Hello,
I had Face ID failure on my IPhone X phone. So I decided to fix it. I did all the steps in full and pass the module to a new flex. When doing the test with my I2C tester it passes all the tests (leds turn on...) but the NTC fails. I don't know if it's the fault of the new flex I bought or what. Attached photo of the tester and the module.
Thank you very much.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
my too
Do you have any solution?
tarafından
@vanthea - Sorry there is no solution other than letting Apple repair it as they can update the security credentials of the part.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Sorry FaceID and NFC security elements are part of the circuit so while you replaced the part and your tester is telling you the part is working physically, its not going to allow the replacement circuit to work as the security keys are not correct (as they are new). Only Apple has the tool to reprogram the phone for the new key.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Im not replacing it. Im doing a dot projector repair.
tarafından
@pwnorz - See if clearing the FaceID and reloading a fresh image fixes it. The stored image maybe off. Otherwise there maybe security linkage between that is messing you up.
tarafından
Yorum Ekle
Yanıtını ekle
Vladimir sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 1,966
