Ana içeriğe geç
Unknown Short To Ground From 5v Power
I recently found my old Atari Lynx. I installed the power circuit refresh kit (replaced the MOSFET, etc) and the Lynx worked, though turning it on sometimes took a few presses of the button. I did the McWill screen mod next and that went well and seemed ok, but the issue with having to press the power button a few times remained. Next I did a recap of the board, thinking the issue was due to some old/bad capacitors. It appeared to work fine after that, but a day later it refused to turn on at all. I did some testing and I believe there is a short from 5v power to ground. I undid the recap (put the old caps back) and the issue still remains. I don't see any obvious shorts, nothing wrong with any of the solder joints, etc. The only area of the board I haven't touched with the recap is under the shield under the cartridge connector. I guess I'll need to look there. In the meantime, I went back and lifted one leg of each of the caps I had worked on, but the short remains. Any advice on how to track down the short from here?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I haven’t worked on this device before but if you think the short is on the main power rail it will be producing heat on the faulty component. I would put some isopropyl alcohol on the board and look for rapid evaporation or a thermal cam would be even better.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Marc J sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 550
