Ana içeriğe geç
The Jeep Grand Cherokee is a mid-size luxury SUV produced by the American manufacturer Jeep. While some other SUVs were manufactured with body-on-frame construction, the Jeep Grand Cherokee has always used a unibody chassis.
172 Soru Tümünü görüntüle
Why is gas splatter coming from exhaust after fuel filter replaced?
My 2002 Jeep Grand Cherokee Limited WJ 4.7L V8 with California emissions package was slow to start after the starter was replaced. I took it back to mechanic. Diag showed a drop in fuel pressure at the fuel filter, The fuel pressure regulator is in the filter in these WJ models (both 4.0L V6 and 4.7L V8 models). They also found P0523 error code (oil pressure high circuit). The mechanic replaced oil pressure gauge sensor and fuel filter. The fuel filter was installed improperly, hissing and fuel smell. Unable to get back to mechanic, I secured the filter hose. I am now seeing black liquid splatter coming from the exhaust, smells like gasoline.
Error code now is P0108. Sometimes I get P0031, P0131, P0132. I checked and cleaned all fuses and relays in the fuse box in the engine compartment. I checked and cleaned the MAP connector, I replaced the MAP sensor twice. The 2 end sockets on the MAP sensor connector have approx. 3V each while the ignition key is turned to on. I don't have a multimeter at the moment.
After these actions and deleting the OBD2 codes, the WJ runs the same and only has one code, P0108. It runs the same and generates the same code with or without the MAP sensor connected. I clear the code a couple of times, just in case. I start the engine w/o MAP sensor connected and get P0108 again.
Could this have anything to do with fuel filter/pressure regulator being replaced?
How do I check for a vacuum leak at the intake?
Please help, WJ is my only active vehicle
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
John Sabaku all the codes besides the P0108 are related to the O2 sensors.
To check for a vacuum leak, I usually spray (lightly) some starting fluid around the intake while the engine is running. If the engine RPM goes up you know it sucks the starting fluid in from a vacuum leak. Check all the hoses and connectors. I do not like the possibility of gasoline coming from your exhaust. That could be a leaking fuel injector or issues with the fuel rail. It is possible that the injector is leaking after the engine is off. Remove your spark plugs and see what they look like. It’ll give you an idea on how the cylinders are burning. At this point you also should do a compression test or a leak down test to see if there are issues with an individual cylinder.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
John Sabaku sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 147
