Ana içeriğe geç
The Acer Aspire V5-571-6889 was released in January 2013 and can be identified by its model number: MS2361.
I am able to log on to my aspire but I see a blank screen.
I see a blank screen when I log onto my Acer Aspire V5-571P-6831. I already took out the battery and put it back in. What should I do next?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Bernadette Martins if it is a blank screen it may not load your OS. If it is a black screen it may be your screen itself. I suggest you start with connecting an external monitor. Let us know what that shows you. If that is normal, you are most likely having an issues with your LCD and may have to replace the screen. It is also possible that this is a backlight issue. In an darkened room and with the computer turning on, shine a flashlight at an angle against the screen. See if you can make out the background etc,. with that.
If an external monitor also does not show anything, then the issue could be your motherboard (bad GPU, bad BIOS, bad HDD, bad cable, etc) for that we need to rule out the first part of this answer.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Bernadette Martins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 160
