Optical drive connector capability
If I were to use an SSD with the optical drive connector as a primary drive (running the OS), would it run as fast as if connected through the regular cable?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Mactracker database shows both the hard drive and superdrive are SATA 3, supporting 6Gb/s as max speed for your model. It shouldn't be a problem to use the superdrive connector for the main drive, as far as speed is concerned.
Bu yanıt yardımcı oldu mu?
thank you for your answer
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 34
