Ana içeriğe geç
Panasonic LUMIX DMC-LX100, 12,8 MP çözünürlüğe, 4K HD video çekim özelliklerine ve Wi-Fi erişimine sahip kompakt bir dijital fotoğraf makinesidir. Kasım 2014'te piyasaya sürülmüştür.
System Error (Focus) any advice?
Can't get past this message on start up. Any solves?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
christopher.stollery this is commonly caused by a stuck lens. It is possible that teh lens mechanism got "knocked off" it's track or other grit getting into the camera mechanism. First I would remove the existing batteries and the memory card from the camera, wait one minute and then put the batteries and the memory card back and turn the camera on. If that does not work you could try a vacuum cleaner and apply some suction around the lens case. Some people swear by using a piece of paper around the lens area and move it around the gap to possibly dislodge anything stuck in there. Check on here for more ideas. If none of that works, consider replacing the lens. Disassembling Panasonic LUMIX DMC-LX100 - iFixit Repair Guide
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I just removed the battery and the SD card, then put it back after a moment and voila! It works great!
tarafından Paylaş
Yorum Ekle
I pressed and held the menu/set button then turned the camera on. That cleared the problem.
Puan 0
Yorum Ekle
Yanıtını ekle
christopher.stollery sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 73
Her zaman: 8,116
