Ana içeriğe geç
Scientific Casio Calculator released August 2000. Identified by the model name FX-115MS
7 Soru Tümünü görüntüle
How do I fix my transparent solar calculator
I know it sounds fake but those things are real, i couldnt find any pictures of it in the options and mine is kinda broken.
6 works but the other keys don't, i went outside coz i figured that maybe it needed sunlight but it still didnt work. What do i do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Tried disassembling it and cleaning debris collecting between the membrane keypads and circuit board? The carbon film on membrane pads may be worn down and unable to connect circuit lines when pressed onto the board. Other issues may be worn out electronics or damage wiring. If unable to resurrect this calculator then its time to replace it.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
The solar cell charges a battery, they don't last forever so I d open it and see if I could find a replacement battery for it. If you perhaps dropped it there could be just a loose connection so look for anything obvious. Not your device but possibly helpful answer referencing a solar powered calculator repair is here. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
TheGuyWhoAsked sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 209
