Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Can I replace the screen without disconnecting the battery?
I had a cheap screwdriver (got a better one now) and have managed to strip the middle tri point screw on the metal thingy covering the display and battery connections. I just cant get it out. I was thinking of bending the metal thingy to disconnect the display. Should I try this or not? What can go wrong if I dont disconnect the battery?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey, I managed to replace the screen the way I described in the original post and it WORKS! The battery was fully discharged before the repair. Thanks for suggestions.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
you may blow something on the backlight circuit if you dont disconnect the battery, do you have any access to a dremel type tool that you could use to grind off the head of the screw
Puan 2
2 Yorum:
No I do not have anything that small
tarafından
@Vladimír Vlk ok, the only thing you could try is make sure the phone is powered off before connecting the new screen
tarafından
Yorum Ekle
I would wait till the battery completely discharged and then proceed with the replacement. Bad things will happen if you do not disconnect the battery.
Puan 1
Yorum Ekle
Yanıtını ekle
Vladimír Vlk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 15
Her zaman: 205
