Ana içeriğe geç
Device repair and information for HP's line of Pavilion 15" laptop computers.
All screws in chasis are spinning when trying to unscrew them
Hi,
The screws on my HP Pavilion - 15-cw0983na laptop chasis (bar those under the rubber feet) are spinning but not coming out. I have used both magnetic and non-magnetic screwdrivers. I've tried slipping something under the screws to leverage them out but this is just scratching the chasis and screws themselves. I'm not sure what else I can try to get the screws or chasis off but any help is appreciated
TIA!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The plastic around the screws likely broke over time, which is somewhat common on comsumer grade laptops -- much less today, but still occurs. More than likely, the palmrest is compromised.
Don't go prying up prematurely as you will do some damage to the bottom as well, but what you can sometimes do is start to unclip the bottom and then back them out slowly, so you aren't putting as much stress on the "intact" standoffs, if you will. Once you get it off, take a look at the damage and see; if most of them are bad, you may need a new palmrest but if 1 or 2 are broken. If it's not critical/barely visible, it may not be worth the cost to fix correctly and if you care that much, read on since you can sometimes glue them back together. Likewise if it's critical, sometimes you can put Epoxy in the plastic where it broke, push it back in and fix it that way. It will probably break again, but if it means you replaced the laptop or have the parts needed, it did it's job.
I wouldn't glue it in professionally, but if it was my laptop and it wasn't critical/field failure was low risk, I've done it. But these repaired notebooks get "noted" for being fixed this way as it's a half fix so I know if I take it out, I need to be careful and it may break for good.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
theta campanile sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 106
