Ana içeriğe geç
The Durango was marketed as a sturdy truck-based SUV designed to hold up to seven passengers and tow up to 7,500 lb (3,400 kg) when properly equipped.
Won't shift from Park to any gear and no brake lights
Won't shift into gear from Park to any gear no brake lights replace the brake light switch and still same problem
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Did you check if the stop light fuse (Fuse G - 20A) in the fuse block is OK you didn't say?
If the fuse is OK, here's the stop light wiring diagram from the 1998-2000 Durango service manual that shows the wiring for the stop lights.
(click on image to enlarge)
Regarding the gears, check if the gearshift cable is OK. Here's the adjustment procedure.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
MIKE sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 191
